HD quality display with ultra-wide viewing angles, tilt feature, VGA port and VESA-mount compatibility. EcoEnergy saving with power-efficient features.
View your applications, spreadsheets and more on 19.5 inches of 1440x900 HD clarity, with a 16:10 aspect ratio, 16.7 million colors, an 85 percent color gamut and a 178° ultra-wide viewing angle that allows colors to remain consistent from virtually any angle.
Plug and view
Compatible with both legacy and non-legacy PCs via VGA and DisplayPort connectivity.
Mounting option
Keep your desk clutter-free by mounting your VESA compatible monitor on the wall or using the optional Dell Single Monitor Arm, detailed below.
Tilt at will
Work comfortably by tilting the monitor 5° forward or 21° backward.
Convenient controls
Easily access buttons for power, brightness, contrast and customizable preset modes on the monitor's front panel.
Dell E2016 - LED monitor - 20" - with 3-Years Advanced Exchange Warranty
LED-backlit LCD monitor - 20"
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1440 x 900 at 60 Hz
Pixel Pitch
0.2915 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
6 ms (grey-to-grey with overdrive)
Colour Support
16.7 million colours
Colour Gamut
72% (CIE 1931), 85% (CIE 1976)
Input Connectors
VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
45.421 cm x 18 cm x 39.095 cm
2.81 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, DDC/CI, RoHS, CECP
3-year warranty
Bundled with
Display Type
Diagonal Size
20"
Viewable Size
19.45"
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1440 x 900 at 60 Hz
Pixel Pitch
0.2915 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
Response Time
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
136.75 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, colour temperature, phase, aspect control
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
Adjustable LED power indicator, BFR/PVC-free, Energy Gauge, Mercury free, backlight dimming control, arsenic-free glass
45.421 cm x 18 cm x 39.095 cm - with stand
2.81 kg
Bundled with
VGA
Mechanical
Tilt
Tilt Angle
-5/+21
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, VESA interface support, Dell Soundbar mounting slots
Stand, VESA screw cover
1 x VGA cable
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (Typical)
20 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
With stand - width: 45.421 cm - depth: 18 cm - height: 39.095 cm - weight: 2.81 kg , Without stand - width: 45.421 cm - depth: 5.099 cm - height: 29.795 cm - weight: 2.29 kg
