Rigorous testing and process-quality monitoring help ensure long-term performance reliability.
Environment-conscious
Built to comply with the latest environmental and regulatory standards.
Energy-efficient design
With 14W normal-operation power consumption (typical) and less than 0.5W in active-off mode, the Dell 20 Monitor can help keep energy costs down, particularly in large deployments. Manage power consumption wisely with PowerNap, which you can enable through the Dell Display Manager to either dim the monitor to the minimum brightness level or put it into sleep mode when it is not in use.
Dell E2014H - E Series - LED monitor - 19.45" - with 3-Years Advanced Exchange Service and Premium Panel Guarantee
LED-backlit LCD monitor - 19.45"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (black-to-white)
Colour Support
16.7 million colours
Colour Gamut
83% (CIE 1976)
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
47.39 cm x 16.55 cm x 35.88 cm
Environmental Standards
ENERGY STAR Qualified
Plug and Play, RoHS, CEL
3-year warranty
Bundled with
Display Type
Diagonal Size
19.45"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
83% (CIE 1976)
Response Time
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
LED backlight
47.39 cm x 16.55 cm x 35.88 cm - with stand
Bundled with
DVI-D (HDCP) , VGA
Mechanical
Tilt
VESA Mounting Interface
100 x 100 mm
Stand, VESA screw cover
1 x VGA cable , 1 x DVI cable
Security Slot Type
Kensington security slot
Input Voltage
Included Software
Dimensions & Weight Details
With stand - width: 47.39 cm - depth: 16.55 cm - height: 35.88 cm - weight: 3.14 kg , Without stand - width: 47.39 cm - depth: 4.65 cm - height: 27.63 cm - weight: 2.41 kg
