Space saving, the Dell Dual Monitor Stand - MDS19 mounts up to two 27-inch monitors, providing the screen real estate you need to be most productive. The dual monitor stand frees up the workspace in front of you for writing and referencing. The round cable management slot neatly channels cables within its stand, routing them along the curved bar with cable clips keeping the cables intact and hidden from view. Each monitor panel is fully adjustable, allowing you to set the height, tilt, pivot, and swivel to suit your viewing comfort. The stand's tool-free installation feature makes it easy to securely snap Dell UltraSharp and P-series monitors with Quick Release into place without the need for screws. It also supports Dell E-series monitors and other 19" to 27" 100 mm x 100 mm standard VESA compatible monitors.
Used stock
All used stock comes with a 90 day warranty.
Condition: Customer return - item has been used but is in excellent condition
Ref: H25C 050920
- Accessories:This part of the stock item is present and in good condition
- Packaging:This part of the stock item is present and in good condition
- Functional:This part of the stock item is present and in good condition
- Software:This part of the stock item is not present or functional
- Manuals:This part of the stock item is present and in good condition
