Affordable, practical and user-friendly, the Dell Chromebook 11 could be the ideal option for you if you're looking for performance on a budget.
This Chromebook laptop comes equipped with a range of premium features, including multiple layers of security to keep all those essential files and sensitive personal information safe under lock and key. Updates are installed automatically, entirely for free.
Dell's Chromebook 11 is simple to use and only takes a few seconds to boot up - so you could be away and working (or playing) in next to no time. Consuming and creating content, connecting with friends and colleagues, and creating and editing documents are all totally easy.
It's powered by a 2.16GHz Intel Celeron processor, and is equipped with 4GB RAM and 16GB SSD storage space - so there'll be more than enough room for all your must-have files. The Chromebook 11's high-density battery gives you seven hours of power, so you can keep going almost all day if you need to.
This model proves that performance and power needn't come at the expense of affordability.
