Help boost office productivity with the robust Dell B3465dnf Mono Laser Multifunction Printer.With advanced security features, productivity solutions and built-in Ethernet, the Dell B3465dnf offers long term value and outstanding performance that you can rely on. Now, you can print, fax, copy, scan and digitally manage documents - all with one easy to use device that will not stretch your budget. With a maximum print resolution of up to 1200 x 1200 dpi, this printer provides high-quality printouts, high-speed printing and reliable performance. Get professional-quality prints at fast print speeds of up to 50 pages per minute (ppm) (letter). A powerful 800MHz dual-core processor and 1GB of onboard memory generate a "first page-out" time of only 6.5 seconds. It includes fast network speed with Gigabit Ethernet connectivity and an optional External Wireless Adapter.
The Dell B3465DNF Mono Laser Printer is able to meet high office printing demands reliably with a large duty cycle of up to 150,000 pages per month (maximum). You can save time and paper with automatic two-sided printing and increase efficiency with built-in Duplex Automatic Document Feeder (DADF) for fast two-sided scanning and copying. Its advanced security features helps you send sensitive documents to the print queue, where they are held until a PIN is entered for secure printing and pickup and Enable and disable printer functions and allow remote access via security templates.
