1 x VGA cable , 1 x DisplayPort cable , 1 x SuperSpeed USB cable
EMC, DDC/CI, RoHS
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (On mode)
15 W
Power Consumption (Typical)
18 watt
Power Consumption Stand by
0.3 watt
Power Consumption Sleep
0.3 watt
Power Consumption (Off Mode)
0.3 watt
Included Software
Dell Display Manager
Dimensions & Weight Details
With stand - width: 53.2 cm - depth: 18 cm - height: 35.71 cm - weight: 5.16 kg , Without stand - width: 53.2 cm - depth: 5.03 cm - height: 31.59 cm - weight: 3.06 kg
