A reliable and affordable monitor with essential features that meet everyday office demands. It features great display quality at multiple angles with VESA-mount compatibility and tilt options, as well as a VGA.
View your applications, spreadsheets and more on Full HD clarity, with millions of colors.
Tilt at will
Work comfortably by tilting the monitor forward or backward.
Convenient controls
Easily access buttons for power, brightness, contrast and customizable preset modes on the monitor's front panel.
Dell E2216HV - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class D
Power Consumption (On mode)
12.9 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
200 cd/m²
Contrast Ratio
600:1
Response Time
5 ms (black-to-white)
Colour Support
16.7 million colours
Colour Gamut
72% (CIE 1931), 85% (CIE 1976)
Input Connectors
VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
51.22 cm x 18 cm x 39.67 cm
3.35 kg
Environmental Standards
ENERGY STAR Qualified
Carbon Footprint
440 kg carbon emissions
RoHS, CECP
3-year warranty
Bundled Services
3 years Advanced Exchange Service
Display Type
Energy Class
Class D
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
200 cd/m²
Contrast Ratio
600:1
Colour Support
Colour Gamut
Response Time
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Screen Coating
Anti-glare
Backlight Technology
LED backlight
LED light bar system
51.22 cm x 18 cm x 39.67 cm - with stand
3.35 kg
VGA
Mechanical
Tilt
Tilt Angle
-5/+21
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), LED indicator, integrated cable management, VESA interface support, Dell Soundbar mounting slots, arsenic free, mercury free
1 x VGA cable
RoHS, CECP
Security Slot Type
Kensington security slot
Input Voltage
12.9 W
12.9 kWh/1000h
Power Consumption (Typical)
18 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Dimensions & Weight Details
With stand - width: 51.22 cm - depth: 18 cm - height: 39.67 cm - weight: 3.35 kg , Without stand - width: 51.22 cm - depth: 5.05 cm - height: 30.37 cm - weight: 2.83 kg
