Slim borders create a smoother and less obstructed visual experience when working across multiple monitors.
Versatility you can count on
Enjoy full adjustability to pivot, tilt, adjust the height, and swivel your monitor to your exact preference.
More ways to stay connected
Multiple connectivity ports on the bottom and side of the monitor allow you to easily connect to various devices.
Enhanced viewing experience
The Dell 19 monitor P1917S is perfect for professionals who work long hours and depend on a monitor that will display stunning visuals without inducing eye fatigue.
Complete clarity
Get excellent picture quality with consistent color representation across an ultrawide viewing angle and a high 4000000:1 dynamic contrast ratio.
Work comfortably with less stress
Dell's ComfortView feature helps to reduce harmful blue light emission onscreen and with direct current, a flicker-free viewing experience is enabled.
Auto mode and PowerNap
Color settings of your applications are now customizable and allow for presets. And with PowerNap, you can worry less about wasting energy when you're away from your computer.
Reliable and responsible
Enjoy peace of mind with Dell services and eco-conscious features designed to keep you moving forward.
Dell P1917S - without stand - LED monitor - 19"
LED-backlit LCD monitor - 19"
Energy Class
Class D
Energy Consumption per Year
17 kWh
Power Consumption (On mode)
11 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 60 Hz
Pixel Pitch
0.293 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 4000000:1 (dynamic)
Response Time
6 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
Colour Support
16.7 million colours
Colour Gamut
72% (CIE 1931), 84% (CIE 1976)
Input Connectors
HDMI, VGA, DisplayPort
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
40.56 cm x 5.03 cm x 33.43 cm
2.6 kg
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
RoHS, CECP, CEL
Display Type
Energy Class
Class D
17 kWh
Diagonal Size
19"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.293 mm
Pixel Per Inch
86
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
