Compatible with Windows 7 via simple driver download
EXCEPTIONAL PERFORMANCE
The D-Link RangeBooster N® USB Adapter (DWA-140) is a 802.11n compliant wireless client for your desktop or notebook PC. It delivers up to 12x faster speeds* and 4x farther range* than an 802.11g network while staying backward compatible with 802.11g networks. Once connected, you can share a high-speed Internet connection, photos, files, music, printers, and more.
GET CONNECTED, STAY CONNECTED
The RangeBooster N USB Adapter is powered by RangeBooster N technology to provide superb wireless performance in the home or office. Connect to a RangeBooster N Router (DIR-625) and experience smooth Internet phone calls (VoIP), responsive network gaming, secure Web surfing, faster file transfers, enhanced audio streaming, and greater wireless coverage in larger homes and offices*. The DWA-140 supports WPA™ and WPA2™ encryption that allow you to connect securely to a wireless network.
EASY TO SETUP, EASY TO USE
D-Link's Quick Adapter Setup Wizard guides you step-by-step through the installation process. Configure this USB adapter without having to call a networking expert to help you. The D-Link Wireless Manager is also included with this product to keep track of your most frequently accessed networks so that you can join them quickly and easily.
With unmatched wireless performance, reception, and security protection, the D-Link RangeBooster N USB Adapter (DWA-140) is a great choice for easily adding or upgrading wireless connectivity to your desktop or notebook PC.
WHAT THIS PRODUCT DOES
Connect your desktop or notebook computer to a wireless network and access a high-speed Internet connection, transfer files, and stream media from greater distances around your home or office.
RANGEBOOSTER N® ADAPTER BENEFITS
*Delivers up to 12x faster speeds and 4x farther range than 802.11g
*Access secure networks using WPA™ or WPA2™ encryption
*Backward compatible with 802.11g networks
*Easy to install and use with the included Quick Adapter Setup Wizard
Maximum wireless signal rate derived from IEEE Standard 802.11g and 802.11n specifications. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual data throughput rate. Environmental factors will adversely affect wireless signal range. Wireless range and speed rates are D-Link RELATIVE performance measurements based on the wireless range and speed rates of a standard Wireless G product from D-Link. Maximum throughput based on D-Link's 802.11n devices.
Write a review for the D-Link RangeBooster N USB Adapter here!
Do not waste your money.
This unit caused many problems, unlike my Belkin 54 Mbps unit.
If you like me use a BT Homehub, this only transmits a maximum 54 Mbps WiFi.
So the claimed 300 Mbps is not needed, that’s if it ever works.
Better still use a patch cable from the router to the PC and get a true 100 Mbps.
Or use a Belkin 54/125 Mbps WiFi unit, which works very well.
Have read that the Belkin 300 Mbps unit, is also unstable, unless of course you know better.
Hope this helps,
Very easy to setup and works fine.
I have not had any problems with it whatsoever. Comes with a USB extension cable too, which was a nice surprise.
Installed drivers from CD, plugged into USB, entered wireless network details and it worked! Up and running in just a few minutes. I am using with D-link N Router so this might have helped. Stable signal strength about 60% with no dropouts.
Works fine for me!
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
