- Smart Plug (DSP-W215)
- Wi-Fi Motion Sensor (DCH-S150)
- Monitor HD (DCS-935L)
This clever little starter kit gives you the ability to set, control,
monitor and automate your home from anywhere. The Smart Home HD Starter Kit
includes a Smart Plug (DSP-W215), a Wi-Fi Motion Sensor (DCH-S150) and a
Monitor HD (DCS-935L).
These devices talk to each other and with the mydlink Home smartphone and
tablet app you can decide what it is you would like them to do. This is
clever stuff implemented to make your life easier and safer with added peace
of mind. It is smart home technology at its most futuristic.
Easy To Set Up
Simply download the mydlink Home app and the step by step setup wizard will
help you set up all the devices in the kit
Do-It-Yourself Simple, No Installation Fees, No Monthly Charges
Your mydlink™ Home
mydlink™ Home allows you to start with this convenient starter kit and add
more when you want to. The unique mydlink™ Home App1 for iOS and Android
smartphone and tablet puts you in control of all your mydlink™ Home smart
devices. You can even setup automation rules to make your home smarter.
mydlink Home Smart Plug - DSP W215
Turn Devices On/Off with Smart Plug
Instantly turn devices on or off from your iOS or Android smartphone or
tablet using the mydlink™ Home app, wherever you are Create on/off schedules
to have your appliances work for you when you want them to. The integrated
thermal sensor automatically turns off overheating power sockets, giving you
peace of mind2. Automatic alerts to notify you when an appliance has been:
Turned on/off, Power consumption limit is exceeded, If the appliance
malfunctions and overheats
mydlink Home Monitor HD - DCS 935L
View From Anywhere with Monitor HD
Monitor your home in HD 720p.
See everything in detail, even when zoomed in.
Alerts you with push notification whenever motion or sound is detected
Built-in night vision function allows you to see up to 5 metres even in
complete darkness
mydlink Home Motion Sensor - DCH S150
Enhanced Motion Detection with Wi-Fi Motion Sensor
The passive Infrared (PIR) motion sensor greatly reduces false alarms to
ensure you are alerted only when needed Motion detection up to 8 metres
(100° horizontal / 80° vertical). Automatic alerts to notify you when motion
is detected
