The mydlink Home Panoramic HD Camera allows you to monitor more of your home with a single camera. Forget pan, forget tilt, see everything instantly in full color high definition 720p with sound. The integrated microSD card slot1 allows you to record videos directly onto the camera when motion or sound is detected, without the need of a computer. It's easy to setup, connects to your home Wi-Fi and can even alert you when motion or sound is detected. What's more, it works with other mydlink Home smart devices to enable you to create a smart home without complicated setup, installation cost or monthly subscription charges.
