The mydlink Home Monitor 360 allows you to monitor your home, whenever, from wherever. Not only does it pan and tilt to cover wider areas, the built-in night vision allows you to see up to 8 meters even in complete darkness. It's easy to setup, connects to your home Wi-Fi and can even alert you when motion is detected. What's more, it works with other mydlink Home smart devices to enable you to create a smart home without complicated setup, installation cost or monthly subscription charges.
