Introducing the first member of the new Ultra Performance Series of networking devices, the Wireless AC3200 Tri-Band Gigabit Router (DIR-890L).
Equipped with the most advanced features and optimized for maximum speed, coverage and performance, the Wireless AC3200 Tri-Band Gigabit Router (DIR-890L) gives you ultra-enhanced network performance ideal for large homes and demanding users. Now you can experience uncompromised HD streaming and gaming on each and every connected device in and around your home.
Advanced Features that will make you FEEL THE DIFFERENCE
Enhanced quality of service (QoS), ultra fast connectivity and DLNA support combine to provide a buffer-free 4K HD video streaming experience.
Dual core processor, Gigabit ports, and advanced QoS combine to deliver lagfree gaming.
Advanced QoS prioritizes the most important data so you get lag-free gaming and uninterrupted streaming on multiple devices.
Designed to get maximum performance from the growing number of connected devices in the home.
Gigabit Ports provide all of your wired devices with blazing fast 10/100/1000 Mbps connections.
Dual USB Ports (USB3.0 & USB2.0) let you locally and remotely stream content from up to two connected USB drives using the free mydlink SharePort app.
Advanced wireless security with WPA2 and enhanced network security with dual active NAT and SPI firewalls.
Free mydlink Lite mobile app for monitoring and controlling your network.
Backward compatible and optimized to get the best performance out of both legacy and newer Wi-Fi devices.
- Next Generation 11AC Wi-Fi - Newest AC technology for ultra high-speed wireless connections
- Simultaneous Tri-Band - Delivers faster Wi-Fi speeds of up to 3200Mbps (600Mbps on 2.4Ghz + 1300Mbps + 1300Mbps on 5GHz)
- Ultra Range - Powerful amplifier, 6 high-gain antennas and Advanced AC SmartBeam technology combine for enhanced Wi-Fi speed and coverage *
- SmartConnect - Increases bandwidth efficiency and availability
- Dual Core Processor - Gives you increased performance to support more devices and provide faster throughput
- Gigabit Ethernet - Delivers wired performance 10x faster than traditional Fast Ethernet
- Your Own Personal Cloud Storage - mydlink SharePort enabled USB port so you can store and access your media files wherever you are
- USB 3.0 - Up to 10x faster than USB 2.0
- Compatibility - Works with existing and future Wi-Fi devices
