D-Link's DHP-509AV PowerLine AV 500 HD Starter Kit makes it easy to create a high-speed network using your home's existing electrical wiring. Extend your home network to places where you currently have no Internet access, such as a garage or basement. The kit includes two DHP-500AV PowerLine 500 HD Adapters - Simply plug one adapter into your existing router to turn any power outlet in your home into an Internet connection and then plug the other adapter into the room you want to extend your connection to.
Plug-and-Play feature means extending your homes wi-fi is simple and easy.
PowerLine AV 500 technology make it ideal for streaming HD media
HD Enabled, allowing smooth HD video streaming, Internet VoIP calls and lag-free online gaming experiences
PowerLine AV 500 Technology
The D-Link PowerLine AV 500 Gigabit Starter Kit (DHP-509AV) delivers the ultimate in wired connectivity for the hard-to-reach areas of your home. Utilising your home's existing electrical wiring as a reliable high-speed network, the DHP-509AV makes it easy to connect computers, gaming consoles, and media players to your network without additional cables. The DHP-509AV is the ideal solution for getting connected in spaces like offices, bedrooms and those hard to reach areas of your home where your wi-fi signal does not reach.
How does it work?
PowerLine gives you the flexibility to create the network you need in the space you have, by using your homes electrical wiring to connect computers and other devices. It's a simple solution to what can be a sticky networking situation.
Plug into power sockets, Connect your wired device, Enjoy your high speed HomePlug network!
Hassle-free plug and play installation
Plugs directly into a power socket with no additional cables required.
This adapter implements 128-bit AES data encryption at the push of a button to protect your network from any intruders.
Power saving mode
If no data transmission or reception occurs over a certain period of time, the adapter will automatically go into sleep mode to save power, reducing power usage by around 70%.
