Keep an eye on your little one with the DCS-820L EyeOn Baby Monitor Junior Plus. This portable camera transforms your mobile device into a versatile, yet easy to use baby monitor. Connect to the camera wirelessly or over the Internet so you can check on your infant no matter where you are. It includes a wide array of features to help you care for your child, including motion and sound detection, night vision, automatic snapshots and recording (SD card not included; SDHC Class 6 card or above is recommended; supports card capacities up to 32GB). It can even play gentle lullabies to help ease your baby to sleep!
The EyeOn Baby Monitor Junior Plus is specially designed to make it easy for you to care for your baby. Its versatile all-day monitoring turns on night vision automatically when it gets dark, giving you a clear picture day or night so you can keep an eye on things anytime. It's perfect for use in the home, or even when you're away; it's mydlink-enabled, which means that you can check on your baby remotely and securely over the Internet.
The EyeOn Baby Monitor Junior Plus can send you notifications to alert you to specific events. It can detect movement and loud noises such as crying, and this can trigger recording of snapshots and video clips that you can review later.
You can take the EyeOn Baby Monitor Junior Plus with you when traveling with your child, even when there is no available Internet connection. Just connect your mobile device to the EyeOn Baby Monitor Junior Plus' wireless network for instant local monitoring, making it perfect for family holidays or just visiting friends. You can even connect it to an external USB battery (USB battery not included, requires at least 2 A output) for total portability!
Getting started is quick and easy; the free mydlink Baby Monitor app for iOS and Android mobile devices not only guides you step by step through the setup process but also gives you an easy to use interface for all the advanced features of the EyeOn Baby Monitor Junior Plus. Check on your baby at a glance, pinch to zoom in and out with ease or play one of five gentle lullabies to soothe your child. You can even take snapshots and video clips and save them directly to your mobile device!
Just download the free mydlink Baby Monitor app for your smartphone or tablet and you can quickly and easily setup and view your EyeOn Baby Monitor Junior Plus from anywhere with a wireless or 4G LTE/3G connection. You can also log onto the secure mydlink web portal on your computer to keep an eye on what matters most.
