The D-Link DCS-7000L Mini HD PoE Bullet IP Camera is a mydlink-enabled IP surveillance camera that lets you monitor an area 24 hours a day. This D-Link DCS-7000L Mini Bullet IP Camera is built with a megapixel image sensor to give you high-quality snapshots and video with resolutions up to 720p HD. This D-Link DCS-7000L Mini Bullet IP Camera has built-in Wireless AC technology which gives you better streaming and increased reliability, and it's mydlink-enabled, so you can check on things right from your mobile device.
24/7 HD Surveillance
This D-Link DCS-7000L Mini Bullet IP Camera is built with a megapixel image sensor to give you high-quality snapshots and video with resolutions up to 720p HD. This gives you sharp, high-resolution snapshots and videos with rich detail. Get a closer look with ePTZ, which lets you zoom in, zoom out, and pan across your camera's video so you can survey a large area easily. An infrared cut removable (ICR) filter is also built into this D-Link DCS-7000L Mini Bullet IP Camera, which blocks infrared light during the day for improved image quality.
At night, it moves out of the way to use all available light for low-light surveillance, and paired with a powerful IR LED illuminator with a 8 meter range, this camera can monitor an area even in complete darkness.
Wireless AC
Connect this D-Link DCS-7000L Mini Bullet IP Camera to your wireless network with Wireless AC, which provides improved speed and range over previous wireless standards. This helps when streaming video across your network by providing more bandwidth and creating a more reliable connection. It also gives you the freedom to install your camera in more places, thanks to increased wireless coverage.
Anywhere Access with mydlink
This D-Link DCS-7000L Mini Bullet IP Camera is mydlink-enabled, which means that you can access and configure your camera remotely, no matter where you are. See your camera's live view through the mydlink website, or download the mydlink mobile app and view your camera directly on your iOS or Android mobile device. Keep an eye on your home while you're at work, or check on the office when you're out on the road; mydlink makes it all possible.
Zero configuration
If you have a mydlink-enabled Cloud Router, setting up and configuring this D-Link DCS-7000L Mini Bullet IP Camera is a snap, thanks to Zero Configuration. Simply connect your camera to its power adapter and then connect your camera to your mydlink-enabled Cloud Router with an Ethernet cable - the camera will automatically be added to your account. mydlink does the hard work for you, allowing even novice users to set up and use their mydlink-enabled cameras immediately.
Built for versatility
This D-Link DCS-7000L Mini Bullet IP Camera comes with a wealth of features that enhance its surveillance capabilities, making it ideal for any situation. The camera can detect motion, allowing it to automatically record video and send you a notification when motion is detected. Audio in and out connectors can be connected to a microphone and speaker, allowing for 2-way communication and making this D-Link DCS-7000L Mini Bullet IP Camera ideal for use in entryways.
A complete, expandable surveillance solution
This D-Link DCS-7000L Mini Bullet IP Camera is a self-sufficient surveillance solution, capable of recording snapshots and video to a microSD card without requiring a PC or network storage device. If you want to expand your surveillance options, D-ViewCam management software is also included, giving you the ability to manage up to 32 cameras with a robust set of features, including multi-camera views and automated e-mail alerts to keep you informed of suspicious or unusual activities.
Key Features
1/4" Megapixel CMOS progressive sensor with HD resolution (1280 x 720)
Audio in and out jacks can be connected to a microphone and speaker for 2-way communication
Built-in infrared-cut removable (ICR) filter for allday surveillance
Built-in Samba client for saving to a network storage drive
Built-in IR LED illuminator with an 8 meter range for use in dark areas
H.264 and Motion JPEG compression and simultaneous multi-stream support
Supports 802.11a/b/g/n/ac and one (1) 10/100 Fast Ethernet port
MicroSD card slot for onboard storage
Supports multiple access lists
Standard Warranty: 2-Years
