D-Link, the industry pioneer in wireless networking, introduces the DWL-G122 Wireless USB Adapter, part of the AirPlus G family of 802.11g wireless networking devices.
Using the DWL-G122 Wireless USB Adapter, you can now enable 802.11g wireless connectivity for your PC using the convenience and speed of a USB 2.0 interface.
Featuring the latest in wireless technology, the DWL-G122 delivers incredibly fast performance and industry-wide compatibility.
By adhering to the 802.11g wireless standard, the DWL-G122 is capable of streaming video and transferring large files across a wireless network.
The DWL-G122 Wireless USB Adapter includes an easy-to-use configuration that discovers available wireless networks wherever you go. The utility can also create detailed connectivity profiles to save your most frequently used networks. You can also enable support for WPA and 802.1x, for better data encryption and user authentication.
The DWL-G122 is a Wireless USB 2.0 adapter that installs quickly and easily into any desktop or laptop PC with an available USB port. You can simply plug in the DWL-G122 to enjoy the freedom of wireless networking. When used with other D-Link AirPlus G products in their default configuration, the DWL-G122 automatically discovers and connects to the wireless network.
Like all other D-Link wireless adapters, the DWL-G122 Wireless USB Adapter can be used in peer-to-peer mode (ad-hoc) to directly connect to other 802.11b/g wirelessly enabled computers for direct file sharing, or in client mode (infrastructure) to connect with wireless access points or routers.
Customer reviews
Write a review for the D-Link AirPlus G 802.11g Wireless LAN USB Adapter here!
Great Value
By
Les.
Posted
29/03/2008
Good range
By
James.
Posted
16/02/2007
Compact, portable, easy to install and it works!
By
Anonymous
Posted
11/09/2005
Read all 14 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
