            The D-Link DGS 1530-10 is a robust switch designed for efficient networking in various environments. With a capacity for 255 IPv4 routes and 4094 VLAN groups, it supports extensive routing and network segmentation. Its stackable design accommodates up to 9 units, allowing for increased flexibility in expansion and management. The switch features a variety of ports, including 8 10/100/1000 Base-T and 2 10 Gigabit SFP+ ports, ensuring connectivity for diverse devices. With a compact form factor, it can be easily rack-mounted or used in desktop setups, making it adaptable to different configurations and spaces. The DGS 1530-10 incorporates features like D-Link Green technology for energy efficiency and is equipped with a fanless design that helps reduce noise in sensitive environments. Its support for advanced protocols such as RADIUS for authentication, VLAN support for network segmentation, and Quality of Service (QoS) ensures appropriate bandwidth allocation for various applications while maintaining network performance. Additionally, its environmental parameters allow for versatile operation in conditions, with temperature ranges from -5°C to 50°C and a humidity range of 0 - 95%, non-condensing.
