The D-Link power adapter is an efficient external power solution designed to meet the needs of PC users requiring a reliable 12 V power source. With a maximum electric current of 3 A, it delivers a consistent 36 W of power, ensuring your device operates smoothly without interruption. The adapter comes equipped with a durable 1.1 m power cable and a power DC jack 3.8 mm connector, making it versatile for a wide range of setups. Its compact and robust design not only makes it easy to transport but also ensures it stands up to the demands of daily use. Whether you're at home, in the office, or on-the-go, this power adapter is the perfect solution for keeping your PC powered and ready to go.
