The CyberPower (PDU20SWHVIEC8FNET) 8-outlet 1U rack mount switched power distribution unit (PDU) provides 200-240V 20A output. It distributes power to 8 IEC-320 C13 receptacles from a single IEC-320 C20 plug, with unfiltered electrical pass-through. Outlets can be managed individually over the network, using CyberPower Management Console and the RJ45 Ethernet port for local network connection, or locally using the LCD. The LCD displays the electrical current of connected equipment in amps and can be toggled to display input voltage, power being consumed in watts, and the PDU's IP address. The CyberPower Management Console offers remote management of the unit: monitoring PDU vitals as well as controlling outlets and networked clients.
This unit has a rugged, industrial-grade metal housing and a 10-foot AC power cord. It can be mounted horizontally or vertically, includes a cord retention tray and is UL60950 1 & FCC Class A certified.
