Back
Generic Memory
Crucial 16GB DDR4 2666 MT/s (PC4-21300) CL19 DR x8 Unbuffered SODIMM
Quicklinx:
DDMKWS00
Mfr#:
CT16G4SFD8266
Back
Marketing description is not available.
Crucial - DDR4 - module - 16 GB - SO-DIMM 260-pin - 2666 MHz / PC4-21300 - unbuffered
Memory module
16 GB
Memory Type
DDR4 SDRAM - SO-DIMM 260-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2666 MHz (PC4-21300)
Latency Timings
CL19
Dual rank, unbuffered
Voltage
1.2 V
Limited lifetime warranty (Germany - 10 years)
16 GB
Upgrade Type
Generic
DRAM memory module
DDR4 SDRAM
SO-DIMM 260-pin
Speed
Latency Timings
CL19
Non-ECC
Module Configuration
2048 x 64
Chips Organization
X8
Voltage
1.2 V
