Back
Generic Memory
Crucial 12GB 3x4GB DDR3-1066 CL7 ECC Memory Module
Quicklinx:
7T78WS00
Mfr#:
CT3KIT51272BA1067
Back
Marketing description is not available.
Crucial - DDR3 - kit - 12 GB: 3 x 4 GB - DIMM 240-pin - 1066 MHz / PC3-8500 - unbuffered
Memory kit
12 GB: 3 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
1066 MHz (PC3-8500)
Latency Timings
CL7
Unbuffered
Voltage
1.5 V
Lead Plating
Gold
Kingston KTA-MP1066K3/12G, Kingston KVR1066D3E7SK3/12G
ASUS Z8NA-D6, Z8NR-D12, Z8PE-D12, Z8PE-D18; DFI DK X58, UT X58; Intel Server Board S5500; SUPERMICRO C7X58, X8DAH+-F, X8SAX, X8ST3-F, X8STE, X8STi, X8STi-F, X8STi-LN4; Tyan S7002, S7010, S7012, S7016, S7025
12 GB: 3 x 4 GB
Upgrade Type
Generic
DRAM memory kit
DDR3 SDRAM
DIMM 240-pin
Module Height (inch)
1.18
Speed
1066 MHz (PC3-8500)
Latency Timings
CL7
ECC
Unbuffered
Module Configuration
512 x 72
Voltage
1.5 V
Lead Plating
Gold
Compatible Slots
3 x memory - DIMM 240-pin
ASUS Z8NA-D6, Z8NR-D12, Z8PE-D12, Z8PE-D12X, Z8PE-D18 , DFI DK X58-T3eH6, UT X58-T3eH8 , Intel Server Board S5500BC, S5500WB , SUPERMICRO C7X58, X8DAH+-F, X8SAX, X8ST3-F, X8STE, X8STi, X8STi-F, X8STi-LN4 , Tyan S7002AG2NR, S7002G2NR-LE, S7002GM2NR-LE, S7002WGM2NR, S7010AGM2NRF, S7012GM4NR, S7016GM3NR, S7025AGM2NR
