The advanced design of the SP120 provides the higher static pressure that radiators and heatsinks demand, while maintaining a quiet noise profile. Seven ultra-wide, custom-molded blades deliver high static pressure, and the customized fan enclosure helps airflow move in the right direction. The rubber mounts and the advanced hydraulic bearing system combine high reliability with low-noise operation. Three included colored rings allow you to customize the look of the fan to match the rest of your hardware.
The wide body, low-pitch blades are custom-molded for high static pressure air delivery with low noise, while rubber corners reduce vibration and noise. An excellent, quiet choice for heatsinks and radiators
The wide body, low-pitch blades of the SP120 fans combined with the custom housing provides outstanding static pressure and airflow through heatsinks or radiators. With rubberized corners, a quiet and reliable Advanced Hydraulic Bearing, and PWM support for increased fan speed control, the SP120 truly is the strong, silent type.
Included in the box are the three user-replaceable colored rings, in red, blue, and white, so you can customize your fan to match your case's components. Each fan also features blacked-out wires and connectors, so your build looks elegant and clean when done. Available in single and twin packs.
- The SP120 PWM Quiet Edition, at full RPM, is an extremely quiet 23dBA while maintaining an impressive 1.29mm/H2O static pressure level.
- 4-PIN PWM Support for increased fan speed control.
- Seven wide body, low-pitch custom blades for optimal static pressure at very low noise levels.
- Custom fan enclosure for ducting air in the right direction with minimal interference.
- Advanced Hydraulic Bearing for reliable, quiet operation.
- Rubberized corners for sound damping when installed with standard screws.
- User-replaceable colored rings so you can match your fans to your case
