Corsair Obsidian Series 550D quiet mid-tower case: The strong, silent type.
The Obsidian Series™ 550D has been carefully engineered for noise reduction. The front and side panels are insulated with sound dampening material, and the hard drive trays and fans have soft silicon mounts to absorb vibration. The top and side panel vents are covered for noise reduction if you're not using them to install your own fans, and even the intakes are angled to reduce air noise.
The rigid, stamped steel and brushed aluminium case holds some remarkable technology that makes it easy to build great systems. There's built-in USB 3.0 support, and the drive trays work with 2.5" SSDs. The removable hard drive bays allow customization for extra-long graphics cards and maximizing airflow. And, the easy-access side panels come off at the touch of a button for easy upgrades or simply admiring your work.
- Insulated, sound dampened side and front panels
- Six tool-free hard drive trays with integral SSD support and soft silicon sound dampening
- Four tool-free optical drive bays
- Angled air intakes for reduced noise
- Covered vents for noise reduction if additional fans (not included) are not installed
- Front panel USB 3.0 connectors and audio connectors
- Cable routing cut-outs with rubber grommets
- Removable, reversible front panel
- One-button side panel removal for quick access
- Matte black interior
- Three 120mm fans
- Top panel is compatible with 240mm radiators for dual-radiator Hydro Series™ CPU coolers and liquid cooling systems
- Eight expansion slots for multi-GPU compatibility
- Dimensions: 20.9" x 8.7" x 19.5"
- Material: Brushed aluminum with steel structure
- Color: Black
- Model: CC-9011015-WW
- Drive Bays: (x4) 5.25" / (x6) 3.5"/2.5" Drive Caddies
- Cooling: (x2) 120mm Intake fans / (x1) 120mm Exhaust Fan
- Expansion Slots: 8
- Motherboard: ATX, mATX
- Front I/O: (x2) USB 3.0, (x1) IEEE 1394 Firewire, (x1) Headphone, (x1) Mic
- Power Supply: ATX (not included)
- Warranty: Two Years
Box Contents
- Corsair Obsidian Series 550D case
- Accessory kit
- Quick Start Guide
