How To Install: Corsair Hydro Series H80 and H100 Liquid CPU Coolers
Hydro Series™ H80 High Performance Liquid CPU Cooler
The Hydro Series H80 and H100: efficient cooling, simple installation, and the power of Corsair Link Digital.
The digital fan control button allows you to select between Quiet, Performance, or Balanced modes.
Ready for Corsair Link Digital.
The H80 and H100 work great with Corsair Link, an ecosystem of hardware and software components designed to give you unprecedented control over your PC. Connect your H80 or H100 to the Corsair Link Commander (available separately) and monitor a wide range of parameters, including pump speed, coolant temperature, and fan speed, and customize your own performance profiles.
Control at your fingertips.
The low-profile integrated pump and cold plate includes push-button control so you can select the fan speed and cooling performance setup that best suits your needs. The cool white LED display lets you know at a glance which profile is being used.
The Hydro Series H80: Compact and quiet.
The H80 includes a double-thick radiator and two 120mm fans. It can be installed almost anywhere you can install a standard 120mm PC case fan, and includes mounting brackets for all modern CPU sockets.
Corsair Hydro Series makes it easy to go liquid.
Easy installation, zero maintenance.
You no longer need to invest into finicky modular watercooling systems to get serious CPU cooling performance. Each Hydro Series Liquid CPU Cooler is a sealed, closed-loop system that comes pre-filled and never needs refilling. Tubing is constructed from low-evaporation FEP for a long lifespan. Even the thermal compound is pre-applied. You'll be up and running in minutes.
The latest cooling technology
Both the H80 and the H100 include a low-profile, light-weight cooling unit with a micro-channel copper cold plate and a split-flow manifold. The result of all this attention to fluid dynamics is CPU cooling that's remarkably efficient, with a total noise level that's lower than most stock CPU fans.
Package contents
Corsair H80 Liquid CPU Cooler
Two 120mm fans
Mounting screws for fans and radiator
Mounting brackets for Intel™ LGA 775/1155/1156/1136/2011 and AMD AM2/AM3
Quick Start Guide
Technical Specifications
Radiator dimensions: 120mm x 152mm x 38mm
Fan dimensions: 120mm x 120mm x 25mm
Fan speeds (+/- 10%): up to 1300 RPM (Low Noise), 2000 RPM (Balanced), and 2500 RPM (High Performance)
Fan airflow: 46 - 92 CFM
Fan dBA: 22 - 39
Fan static pressure: 1.6 - 7.7mm/H20
Compatibility
Intel LGA 775, 1155, 1156, 1366, and 2011
AMD sockets AM2 and AM3
Hydro Series H80 requires a case with a rear or top 120mm fan mount
The H80 includes a double-thick radiator and two 120 mm fans. It can be installed almost anywhere you can install a standard 120 mm PC case fan, and includes mounting brackets for all modern CPU sockets.
Ready for corsair link digital
The H80 works great with Corsair link, an ecosystem of hardware and software components designed to give you unprecedented control over your PC. Connect your H80 to the Corsair link commander and monitor a wide range of parameters, including pump speed, coolant temperature, and fan speed, and customize your own performance profiles.
You no longer need to invest into finicky modular water-cooling systems to get serious CPU cooling performance. Each Hydro Series Liquid CPU Cooler is a sealed, closed-loop system that comes pre-filled and never needs refilling. Tubing is constructed from low-evaporation FEP for a long lifespan. Even the thermal compound is pre-applied. You'll be up and running in minutes.
The H80 includes a low-profile, light-weight cooling unit with a micro-channel copper cold plate and a split-flow manifold. The result of all this attention to fluid dynamics is CPU cooling that's remarkably efficient, with a total noise level that's lower than most stock CPU fans.
CORSAIR Hydro Series H80 High Performance Liquid CPU Cooler - processor liquid cooling system
