Hydro Series H110i is an all-in-one liquid CPU cooler with a 280mm radiator and dual SP140L PWM fans for cooling that’s far superior to stock CPU cooling fans. Liquid cooling simply works better than air cooling, and the self-contained design of the H110i makes it easy for you to protect your valuable CPU.
For efficient cooling, bigger is better – it’s simple physics. If your PC’s case can fit a 280mm radiator, Hydro Series H110i will give you better performance. It’s Corsair Link compatible, so you can customize cooling performance, monitor system temperature, and change the color of the RGB LED lighting.
- Large 280mm radiator: More cooling capacity for cases which have 280mm radiator mounts.
- Improved coldplate and pump design: Better efficiency gives you lower temperatures with less noise.
- Advanced SP120L PWM fan design: Better high-static pressure air delivery and customizable speed.
- Built-in Corsair Link: Monitor CPU and coolant temperature, adjust fan speed, and customize lighting directly from your desktop.
Includes:
- Corsair Hydro Series H110i Extreme Performance Liquid CPU Cooler
- Mounting kit for all modern CPU sockets
- Two SP140L High Torque 140mm fans
- USB cable for Corsair Link. Integration
- Fan and radiator mounting screws
- Thermal compound (pre-applied)
- Quick Start Guide
