Hydro Series H100i v2 is an all-in-one liquid CPU cooler with a 240mm radiator and dual SP120L PWM fans for cooling that's far superior to stock CPU cooling fans. Liquid cooling simply works better than air cooling, and the self-contained design of the H100i v2 makes it easy for you to protect your valuable CPU.
The H100i v2 has Corsair Link built in. Just attach the included cable to a USB header on your motherboard and download the free Corsair Link software, and you can monitor CPU and coolant temperatures, adjust fan speeds, and customize the LED lighting directly from your desktop.
- 240mm dual-fan radiator: More surface area for superior cooling performance.
- Improved coldplate and pump design: Better efficiency gives you lower temperatures with less noise.
- Advanced SP120L PWM fan design: Better high-static pressure air delivery and customizable speed.
- Built-in Corsair Link: Monitor CPU and coolant temperature, adjust fan speed, and customize lighting directly from your desktop.
- User replaceable inserts: Change the colour of your cooler to match your system with the user-replaceable inserts on the radiator and pump cap (Sold Separately).
Includes:
- Corsair Hydro Series H100i v2 High Performance Liquid CPU Cooler
- Mounting kit for all modern CPU sockets
- Two SP120L High Torque 120mm fans
- USB cable for Corsair Link Integration
- Fan and radiator mounting screws
- Thermal compound (pre-applied)
- Quick Start Guide
