The Graphite Series 760T features an industry-first fully windowed side panel, but don't let its looks fool you - it's got tons of expansion room and cooling capabilities. With nine expansion slots, room for a 360mm radiator up top and a 280mm radiator in front, six tool-free, modular hard drive bays and four side-mounted SSD trays, you'll have a hard time filling it up with parts. And with dual front AF140L LED intake fans and a single AF140L rear exhaust, you'll have tons of airflow to keep everything nice and cool.
The 760T gives you a ton of flexibility to build the gaming rig you've always dreamt about. And the full side panel window gives you the freedom to show it off.
- Gorgeous full panel window for maximum visibility of your internal components.
- Hinged side panels with quick release latches for easy access.
- Generous expansion room for building high-performance systems.
- Tool-free SSD, Hard Drive, and Optical Drive installation.
- Includes three AF140L fans, (front fans with LEDs) with room for up to seven fans. (NOTE: Black version has RED LED on front fans, Arctic White version has WHITE LED on front fans)
- Fan speed toggle switch allows you to set your fans to "silent" or "performance" modes.
- Modular drive cage system for highly customizable layouts.
- Two modular drive cages house three 3.5" or 2.5" drives each.
- Four tool-free dedicated SSD cages, sideways mounted.
- Designed for fast and straightforward builds.
- Radiator and fan compatibility: Top: 3 x 120mm or 2 x 140mm, Front: 2 x 140mm or 2 x 120mm (2 x 140mm LED included), Bottom: 1 x 120mm, Rear: 1 x 140mm or 120mm (140mm included)
- Two USB 3.0 and two USB 2.0 front panel connectors, plus headphone and microphone.
- Easily accessed dust filters.
- Excellent cable routing with rubber grommets for clean builds.
- Nine expansion slots for multiple PCI-E devices or large motherboards
- Maximum CPU Cooler Height 170mm
- Maximum GPU Length 450mm
- Maximum PSU Length 230mm
