After 20 years of pushing the limits of innovation, Corsair Gaming takes the power of Cherry MX German engineering one step further. With the simple goal of delivering pro-proven mechanical performance paired with outrageous customization options, Strafe will enable your skills to reach their full potential. Brilliant backlighting is enhanced with virtually unlimited dynamic lighting configurations - craft your own, or choose from six unique presets. And, gold contact Cherry MX mechanical keys deliver the ultimate competitive advantage. Rated for an industry-leading 100 million key presses, they guarantee a lifetime of consistent, comfortable response.
- Cherry MX Switches - Fast, precise, durable Cherry® MX
- Per Key Backlit - Backlighting for outrageous customization
- Fully Programmable - Reassign and create any key combo
- USB Port - Easily connect most devices via USB
- Comfort and Control - Textured and contoured keycaps
- Gaming Circuitry - 100% anti-ghosting for however fast you play
- Easy Access Media - Adjust your media volume on the fly
CHERRY MX BROWN KEY SWITCHES
Used by the pros and built in Germany. Cherry MX gaming keys feature the worlds leading mechanical key switch technology. Gold-Crosspoint contacts, Gold-plated contact closure, and pressure resistant metal alloy springs, give every gamer the competitive advantage.If you're playing MMOs and MOBAs, it's often less about getting your shots in, and more about moving out of fire. Cherry MX Brown switches give you light tactile feedback, so you know exactly when the keypress is registering.
DYNAMIC BACKLIGHTING
Brilliant RED backlighting enhances the experience with virtually unlimited lighting adjustability. Choose from six unique presets or craft your own.
ENDLESS PROGRAMMABILITY
The Corsair Utility Engine (CUE) unlocks amazing keyboard programmability. Reassign any key or set up the most extreme macros for outrageous gaming control.
GET CONNECTED
Positioned for uninterrupted game play, the built in USB pass-through provides easy connection for your mouse, USB drive, or wireless headset adapter.
