Enjoy legendary audio with zero hassle. You get 2.4GHz wireless freedom at up to 40 feet, and ten hours of uninterrupted gaming at a time. Genuine Dolby 7.1 surround gives you lethally accurate positional audio, and the 50mm neodymium drivers produce staggering bass, highs, and dynamic range. Marathon gaming sessions are easy with the microfiber-wrapped earpads, and you'll be heard loud and clear with the unidirectional noise-cancelling microphone.
- Legendary audio, zero hassle: 2.4GHz wireless freedom up to 40ft + 10 hours of uninterrupted gaming
- Epic immersion and true multi-channel audio: genuine Dolby 7.1 surround delivers lethally accurate positional audio
- Unlock legendary audio: Oversized 50mm neodymium drivers bring the action to life with brilliant range and precision
- Embark on marathon gaming sessions: comfortable microfiber-wrapped memory foam earpads enable extended play.
- Take command: the advanced unidirectional noise-cancelling microphone makes you loud and clear
