Flash Voyager Slider X2 is a compact USB 3.0 drive that doesn’t sacrifice size for performance. It has a smart design, with a USB connector that retracts for protection when you’re not using it. An activity LED tells you at a glance if it’s transferring data. It supports USB transfer speeds of up to 200 MB/s read and 90 MB/s write. The Slider X2 is backward compatible with USB 2.0, so you can use it with virtually any desktop or notebook.
