Carbide Series SPEC-01 is proof that great looks, smart design, and durable construction don't need to be pricy, and that basic doesn't need to be boring. You get aggressive styling, a huge side panel window for admiring your components, and an LED-lit front intake fan that draws cool air directly to your graphics cards.
Inside, there's room for up to five fans, and the four combination hard drive / SSD trays make storage installation and upgrades quick and easy. Cable routing cutouts help you reduce clutter, and the built-in dust filters help protect your components. Up front, the USB 3.0 connector gets you up to speed with the latest high-performance storage devices.
- Tons of fan mounts: Front - 2 x 140/120mm (1 x 120mm LED included), Top - 2 x 120mm, Rear - 120mm
- USB 3.0 front port with internal connector
- Large side panel window
- Cable routing and CPU cooler backplate motherboard cutouts
- Seven PCIe slots with room for long graphics cards up to 420mm long
- Install up to four storage drives, your choice of 3.5" or 2.5", each tray fits both.
- Dust filters for front and PSU intake.
Box Contents
- Carbide Series SPEC-01 Mid Tower Gaming Case
- Accessories box with screws, zip ties, and other mounting hardware.
- Warranty and Support Information
