The Carbide Clear 400C packs all the performance and expandability you need into a beautifully compact case design. Put your components on display through the gorgeous, full-size window panel that opens with a touch - and keep it all running cool and quiet with Direct Airflow technology.
- Clean, modern lines with an all steel exterior.
- Full side panel window to see your internal parts, complete with tool-free latch and hinge for easy access.
- Compact Mid Tower design fits full sized ATX boards and multiple graphics cards.
- Direct air flow access to the hottest components with no drive cages in the way.
- Capable liquid cooling support for both CPU and GPU loops.
- Included AF140L and AF120L fans for excellent performance and low noise levels.
- PSU and 3.5h modular covers conceal cables and drives, and can be relocated or removed entirely for easy assembly.
- Full dust filtration on bottom, front, and top.
- Tons of cable-routing options and tie downs so cables can be easily tucked out of the way.
- Tool-free drive installation for quick builds.
- Front radiator compatibility for up to a single 360mm radiator or multiple 120/140mm radiators.
