The Air Series AF140 fan lets you have it all. Eleven ultra-thin, custom-molded blades push ample air volume. Rubber corners dramatically reduce vibration. The advanced hydraulic bearing system is quiet and reliable, and you can customize the look.
AF model is ideal for mounting at the rear or top of your PC case as exhaust fan for your PC's motherboard and CPU, graphics accelerators, and other components that fill the case with heat. It works equally well as unrestricted intake fans for areas like side panels or bottom intakes.
