CORSAIR high performance Vengeance memory module 8GB (2x4GB) 1866MHz 9-10-9-27, 1.5V for motherboards using AMD, Intel dual channel processors and 2nd Generation Intel Core Processor platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
Key Features
- 8GB (2x4GB) DDR3 for AMD, Intel Dual processors and 2nd Generation Intel Core Processor platforms
- 1866MHz
- 9-10-9-27 latency
- Vengeance Red heat spreader for styling and performance
- Intel XMP (Extreme Memory Profile) Support
- Limited Lifetime Warranty
Specification
- Density: 8GB (2x4GB Module)
- Speed: 1866MHz
- Timing: 9-10-9-27
- Type: DDR3
- Format: DIMM
- Pin Out: 240 Pin
- Voltage: 1.5V
