Corsair high performance Vengeance memory module 8GB (2x4GB) 1600MHz 9-9-9-24, 1.5V for motherboards using AMD, Intel dual channel platforms. These Vengeance modules are designed for high-performance systems with extra-large CPU coolers, small form factor system builds, or other space-constrained applications that prevent the use of standard Vengeance memory. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- 8GB (2x4GB) DDR3 for AMD, Intel Dual processors
- 1600MHz
- 9-9-9-24 latency
- Vengeance heat spreader for styling and performance
- 10 Years Warranty
Speciifcations
- Density: 8GB (2x4GB Module)
- Speed: 1600MHz
- Timing: 9-9-9-24
- Type: DDR3
- Format: DIMM
- Pin Out: 240
- Pin Voltage: 1.5V
- Warranty: 10 Years
