Corsair built its reputation on performance memory that shines in the most demanding computing situations: extreme gaming and high-transaction processing environments. But not all computers are put to such extreme usage. So we brought the same reliability, testing and Corsair quality to a line of memory designed to support standard computing situations such as popular office applications. Now it's one of our most popular memory lines. Backed with a lifetime warranty, it is memory you can rely on.
- 8GB Kit (2x4GB)
- DDR3 1333MHz DIMM
- 333MHz
- 9-9-9-24 latency
- 10 Year Warranty
- Density: 8GB Kit (2x4GB)
- Speed: 1333MHz
- Timing: 9-9-9-24
- Type: DDR3
- Format: DIMM
- Pin Out: 240 Pin
- Voltage: 1.5V
- Warranty: 10 Years
