CORSAIR high performance Vengeance SODIMM memory module, 8GB (1x8GB) 1600MHz 10-10-10-27, 1.5V, allows you to automatically boost performance of your without bios reconfiguration. Slim and attractive design to ensure physical compatibility with all 2nd Generation Intel Core™ i5 and i7 notebooks. Each module is built using carefully selected DRAM to allow excellent stability and is backed by Corsair's limited lifetime warranty.
Key Features
- 8GB (1x8GB) DDR3 SODIMM for 2nd Generation Intel Core™ i5 and i7 notebooks.
- 1600MHz
- 10-10-10-27 latency
- 1.5V
- Auto-overclocking (no bios configuration required)
- Limited Lifetime Warranty
- Density: 8GB (1x8GB Module)
- Speed: 1600MHz
- Timing: 10-10-10-27
- Type: DDR3
- Format: SODIMM
- Pin Out: 204 Pin
- Voltage: 1.5V
- Note: if two modules are used both should be the same speed and timings
