80 Plus Gold certified modular PSU with a huge seven year manufacturer warranty!
Unprecedented Power Protection
The Corsair Professional Series Gold power supply pushes the state of the art for reliable delivery of clean power under imperfect conditions. If you require mission-critical stability or you simply want one of the best power supplies available, the Professional Series Gold is for you.
A Fully Modular Cabling System
All cables detach from the power supply. During installation, this gives you the flexibility of using only the cables you need for a clean system build with optimal airflow. And, when it's time to replace or upgrade your power supply, it can be removed from your system without interfering with your cabling -- the cables stay in place and connect to your new fully-modular Corsair power supply.
Incredible Efficiency
With 90% efficiency at 50% load, the Corsair Professional Series Gold power supply runs quieter, generates minimal excess heat, and saves you money every month. It's earned the 80 PlusĀ® Gold seal of approval, your guarantee that you're making the right choice for smart,efficient power delivery.
Ultra Low Noise - Hybrid Silent Fan Control
The Corsair AX850's energy-efficient design allows it to operate reliably with minimal cooling, and hence very low noise levels. The AX850's Hybrid Silent Fan Control technology offers three modes of cooling, depending on the load level. This includes a fanless mode of operation (0 rpm) up to about 20% load, a quiet, low fan speed cooling mode for typical loads up to around 50% load, and a higher performance cooling mode for more demanding loads. Noise levels still remain low even when fan speeds start to climb, thanks to the use of a premium-quality 120mm San Ace fan from industry-leader, Sanyo Denki.
