The AXi series PSU is the desktop PC power supply to use digital (DSP) control and Corsair Link to bring you an unprecedented level of monitoring and performance customization. The DSP in the AX760i makes on-the-fly adjustments for incredibly tight voltage regulation, 80 PLUS Platinum Efficiency, and clean, stable power.
AX760i's extreme efficiency earns it coveted 80 PLUS Platinum certification. Less wasted power means minimal excess heat. This can reduce the strain on your other components, and it can save you money over the long run in the form of lower power bills.
