Flash Voyager GS is a large-capacity, high performance USB 3.0 flash drive in a sleek, scratch-resistant brushed metal enclosure.
USB 3.0 speed and USB 2.0 compatibility
PCs and notebooks with USB 3.0 ports offer transfer speed that’s dramatically faster than USB 2.0, but not everybody’s there yet. Flash Voyager GS takes advantage of the faster USB 3.0 interface, while providing full USB 2.0 support.
Works with virtually any system
Flash Voyager GS is compatible with Microsoft Windows, Mac OS X and Linux. No drivers are necessary… just plug it in. In short, if your desktop or notebook has a USB 3.0 or 2.0 port, it’s compatible with the GS.
Key ring compatible
The loop at the end allows for attaching to most key rings.
Note: Some of the listed capacity on a Flash storage device is used for formatting and other functions and thus is not available for data storage. The actual available capacity for data storage is less than what is listed on the products.
