CORSAIR high performance Vengeance SODIMM memory module, 4GB (1x4GB) 1600MHz 9-9-9-24, 1.5V, allows you to automatically boost performance of your without bios reconfiguration. Slim and attractive design to ensure physical compatibility with all 2nd Generation Intel Core™ i5 and i7 notebooks. Each module is built using carefully selected DRAM to allow excellent stability and is backed by Corsair's limited lifetime warrany.
Key Features
- 4GB (1x4GB) DDR3 SODIMM for 2nd Generation Intel Core™ i5 and i7 notebooks.
- 1600MHz
- 9-9-9-24 latency
- 1.5V
- Auto-overclocking (no bios configuration required)
- Limited Lifetime Warranty
- Density: 4GB (1x4GB Module)
- Speed: 1600MHz
- Timing: 9-9-9-24
- Type: DDR3
- Format: SODIMM
- Pin Out: 204 Pin
- Voltage: 1.5V
- Note: if two modules are used both should be the same speed and timings
