The Corsair Builder Series CX430 PSU is designed for worry-free compatibility for your home desktop PC system build or upgrade. With features usually reserved for premium power supplies, they are a great choice for systems where continuous and reliable power delivery and low noise are essential. Inside you will find a power supply that conforms to universal ATX standards, a power cable, and a clear, detailed Quick Start Guide. Corsair Builder Series power supplies get your system up and running quickly and easily, for years of trouble-free operation.The Builder Series CX430 is the ideal choice for PC builders and upgraders who need a great value, quiet and energy efficient PSU for a low/medium specification home or office PC.
- Corsair engineering and quality control
- Plentiful connectors and long cables
- 80 PLUSĀ© Bronze Certified efficiency
- Large diameter, thermally controller fan
- Black housing and all-black sleeved cables and connectors
- 3-Year Warranty
Physical
- Form Factor ATX
- Case Colour Black
- Width 150mm
- Depth 140mm
- Height 86mm
- Weight 2.06Kg
Specifcations
- Model: CX430
- AC Input: 100-240V
- Input Current: 6.3-3.15A
- Frequency: 47Hz - 63Hz
- Max Load Max Output: +3.3V 20A 110W, +5V 20A, +12V 32A 384W, -12V 0.8A 9.6W, +5Vsb 3A 15W
- Total Power: 430W
- Warranty: 3 Years Manufacturers Warranty
