Multi-camera Video Editing & Live Screen Capture!
Move up to more ambitious video-editing projects with Pinnacle Studio 19 Plus. View and edit footage from up to 4 cameras, add transitions and align clips automatically with Audio Syncing in the new Multi-Camera Editor. Get professional-quality sound with new Audio Ducking, which automatically lowers background sound to keep dialog clear. Accelerate your video-editing experience with 64-bit power, support for Intel’s 6th Generation processor (Skylake), and enhanced HD processing and playback performance. With 24-track editing, Live Screen Capture and over 1,800 effects, titles and templates, Pinnacle Studio 19 Plus has everything you need for polished results. Easily share your HD or 3D movies on Facebook, YouTube and Vimeo, on the latest devices, and enjoy an easy authoring experience with Pinnacle MyDVD.
Get started fast
Easily import your videos and photos from any device, and organize them using new Project Bins.
Correct and enhance
Crop, pan and zoom, and clean up your clips before you make your movie. Then use them again in any movie project.
Multi-Camera Editor
Work with footage from 4 cameras to create more dynamic videos. The Multi-Camera Editor lets you screen your footage, switch angles, cut and delete, add transitions and align clips with Audio Syncing.
Live Screen Capture
Record content from your screen and include the footage in movies with Live Screen Capture. Try Snap Capture View to record Windows apps in action. (Works with Windows 8/10)
Make your movie
New to video editing? Just drag and drop elements to make a movie automatically or use the Storyboard mode to plan. More experienced editors can use the timeline for precision editing.
Add some excitement
Choose from over 1,800 2D and 3D effects to surprise and delight your audience. Easily add your most-used effects, filters and transitions to the Favorite section.
Combine video and audio
Multi-layer editing allows you to combine up to 24 video and audio tracks. Ensure foreground and background sound are always balanced with new Audio Ducking and create custom-fit soundtracks with ScoreFitter.
Share the memories
Post your movies online with easy sharing to Facebook, YouTube and Vimeo. Create DVDs, and export your movies to popular formats to play them on game consoles and mobile devices.
Pinnacle Studio 19 Plus Features
Multi-Camera Editor
Work with footage from 4 cameras to create more dynamic videos. The Multi-Camera Editor lets you screen your footage, switch angles, cut and delete, and add transitions. Align clips automatically with Audio Syncing or use markers, date/time or manual syncing. Even use your multi-camera results to create a Picture-in-Picture effect.
Audio Ducking
Balance dialog, narration with background sound for pro-quality audio. With Audio Ducking, Pinnacle Studio 19 Plus detects audio or narration and automatically lowers the volume of background sound. Adjust the Ducking Level and Sensitivity if you wish for even more control.
Live Screen Capture
Record directly from your screen, capturing both system audio and microphone sound, then bring your captured files to the main timeline to use them in movies, presentation and training videos. Snap View Capture works in Windows 8/10 to let you record Windows apps in action.
Make movies in stereoscopic 3D
Import 3D video clips from sources like GoPro® 3D cameras and Panasonic® MVC format. Edit in various viewing modes, add true 3D effects, and enjoy the best quality with NVIDIA® 3D Vision® optimization and GeForce® support. Export to YouTube® 3D, AVCHD™ 3D, and more for viewing on 3D HDTVs, Sony® PS3™, and other 3D devices. Pinnacle Studio Plus even lets you mix 2D and 3D in the same project.
Advanced 3D features
Pinnacle Studio 19 Plus also has advanced stereoscopic 3D features, like editing 3D in the timeline just like HD. Our partnership with NVIDIA® allows NVIDIA® 3D Vision® display in both full-screen and window modes. View 3D on dual monitors and export "side-by-side" formats recognized by most 3D HDTVs. Auto-color correct for both eyes and control stereoscopic 3D depth (parallax effect). When you're ready to go 3D, Pinnacle Studio Plus has everything you need.
