Back
Refinements
Cisco Small Business - PoE injector - 30 Watt
Quicklinx:
B90HWS00
Mfr#:
SB-PWR-INJ2-UK
Back
CONNECTIVITY
Delivers PoE connectivity to 802.3at compliant endpoint devices and backward compatible with 802.3af
WORKS WITH
Compatible with Cisco Small Business Wireless Access Points
DESIGN
Compact design fits easily in WLAN Access Point installations
CONNECTIVITY
Gigabit LAN ports provide high-speed connectivity to the LAN and endpoint device
POWER OVER ETHERNET
Adds PoE capability to a non-PoE Ethernet switch or router
PoE injector - external
200 g
United Kingdom
Input Voltage
AC 100-240 V
Output Voltage
55 V
Power Capacity
30 Watt
5.3 cm x 14 cm x 3.25 cm
Small Business WAP351
United Kingdom
Input Voltage
AC 100-240 V
Frequency Required
50/60 Hz
Output Voltage
55 V
Max Electric Current
0.8 A
Power Capacity
30 Watt
1 x LAN - RJ-45
MTBF
100,000 hours
FCC Class B certified, UL, cUL, RoHS
10 - 85% (non-condensing)
5.3 cm
14 cm
3.25 cm
200 g
Cisco Small Business WAP351
