Cisco 100 series switch works right out of the box, with no software to install and nothing to configure. Each switch port independently sets itself for the optimal speed and determines whether to run in half- or full-duplex mode automatically.
High performance
Cisco 100 series switch delivers the performance you need to run your business applications - including bandwidth-intensive video services - and avoid slow and sluggish networks. It supports up Gigabit Ethernet speeds, unlocking a level of capacity and performance in your business network and letting you transfer large files in seconds.
Reduced energy costs
Cisco 100 series switch is designed to help conserve energy by optimizing power use without compromising performance, which protects the environment and reduces your energy costs. In addition, they support the energy efficient Ethernet standard, which reduces energy consumption by monitoring the amount of traffic on an active link and putting the link into a sleep state during quiet periods. Most of the switches have no fans, so they run silently and unobtrusively while lowering energy costs.
Support for advanced technologies
All switches include advanced Cisco traffic-handling features to keep your applications running at peak performance. Integrated QoS intelligence on all models automatically prioritizes delay-sensitive services such as voice or video to improve your network's performance. Fast store-and-forward switching identifies damaged packets and prevents them from being passed on through the network. All of these features run automatically, with no management or configuration required.
Peace of mind
Cisco 100 series switch delivers the rock-solid reliability you expect from a Cisco switch. The solution has been rigorously tested to ensure optimal uptime and performance. In addition, unlike the purchase of a consumer-grade product, your investment in a Cisco small business network will grow with your business.
Cisco Small Business SG 102-24 - switch - 24 ports - unmanaged - rack-mountable
CSA, UL, UL 60950, CSA C22.2, FCC CFR47 Part 15, FCC Part 15 A
United Kingdom
27.9 cm
17 cm
4.5 cm
2.3 kg
Limited warranty - replacement - lifetime , Limited warranty - power supply and fans - 1 year , Technical support - phone consulting - 1 year , New releases update - 1 year
