Back
Accessories
Cisco Rack-Mount Kit - Catalyst 2960-X Series for 19" - 24" Racks
Quicklinx:
9B0QWS00
Mfr#:
RCKMNT-1RU-2KX=
Back
Marketing description is not available.
RACK MOUNT
For mounting Cisco Catalyst network switches
EASY INSTALLATION
Kit includes two metal brackets and four screws
COMPATIBILITY
For use with Cisco Catalyst 2960-X, 2960-XR and 2960-L network switches
CAUTION
Install network switch with front panel facing down to allow sufficient airflow; allow at least 3 inches (7.6 cm) of clearance around ventilation openings
PEACE OF MIND
Enhanced limited lifetime warranty
Cisco rack mounting kit - 19"/24"
Rack mounting kit
Catalyst 2960X-24, 2960X-48, 2960XR-24, 2960XR-48
Rack mounting kit
Rack Size
19"/24"
Cisco Catalyst 2960X-24PD-L, 2960X-24PS-L, 2960X-24PSQ-L, 2960X-24TD-L, 2960X-24TS-L, 2960X-24TS-LL, 2960X-48FPD-L, 2960X-48FPS-L, 2960X-48LPD-L, 2960X-48LPS-L, 2960X-48TD-L, 2960X-48TS-L, 2960X-48TS-LL, 2960XR-24PD-I, 2960XR-24PS-I, 2960XR-24TD-I, 2960XR-24TS-I, 2960XR-48FPD-I, 2960XR-48FPS-I, 2960XR-48LPD-I, 2960XR-48LPS-I, 2960XR-48TD-I, 2960XR-48TS-I
