Designed specifically for PC use, this power adapter ensures seamless compatibility and efficient power delivery to your devices.
Optimal power management
With a voltage provision of 48 V and the ability to operate on a wide range of input voltages (AC 100 / 240 V), this adapter is engineered for optimal power management and efficiency.
Versatile design
The external form factor of the power adapter makes it a versatile addition to your tech toolkit, allowing for easy Plug-and-Play functionality across various setups.
