Travel light with a pocket-sized, connected powerhouse A pocket-sized, connected travel zoom camera for those who want a versatile lens and powerful features to take on every trip
Pocketable yet powerful Travel light with a pocketable camera that's easy to carry wherever you go
Zoom in on distant detail Get closer to faraway subjects using the huge 40x optical zoom lens; get even closer without any loss of quality with 80x ZoomPlus
Great for ultra-wide shots Capture dramatic landscapes or include everyone in group shots with 24mm ultra-wide angle
Sharp results every time Enjoy sharp, detailed images thanks to an optical Image Stabilizer, which intelligently adapts to the scene and includes a specific Powered Image Stabilisation mode for steady shooting when using the long zoom
Keep your subject in the frame Keep track of distant subjects and enjoy optimal framing at high zoom using advanced Zoom Framing Assist, which intelligently adjusts the zoom level to keep the subject in the frame
Realistic movies Effortlessly shoot realistic Full HD 60p movies in MP4 format with one touch of the Movie Record Button
Short Clip Movie Capture 4, 5 or 6s clips with slow and fast motion playback options using Short Clip Movie
Steady footage Record incredibly steady movie footage at full zoom, when panning or on the move with 5-axis Advanced Dynamic IS to counteract camera shake and Auto Level to ensure straight horizons
Manual control Take your next step in creative photography with full manual exposure control
Powerful 40x optical zoom with Intelligent IS helps optimize image stabilization
With the PowerShot SX720 HS camera in hand, you'll be impressed at the zooming capabilities of this slim, compact digital camera. The amazing 40x optical zoom lens, pack a lot of zoom power into a slim design. The camera's advanced technology helps ensure that images and videos are captured with outstanding quality.
Built-in Wi-Fi technology makes sharing quick and easy
Built-in Wi-Fi technology allows for on-the-go convenience when you want to share your photos and videos with friends and family. Easily post your images in social networking and media. You can control the destination of your uploads to share with everyone or to selected groups, and even add comments.
Built-in NFC technology
PowerShot digital cameras with built-in NFC technology provide fast connectivity for quick, easy sharing of your images. Even if your camera is off, NFC turns the camera on and establishes the connection.
Canon PowerShot SX720 HS - digital camera
Digital camera - 1080p - compact
Memory Card Slot
SD card
Image Processor
DIGIC 6
Wireless Interface
Wi-Fi, NFC
Sensor Resolution
20.3 Megapixel
Max Video Resolution
1920 x 1080
Lens System
Zoom lens - 40x zoom - 4.3 - 172 mm - f/3.3-6.9
Focus Adjustment
Automatic, manual
Min Focus Distance
5 cm
Digital Zoom
4x
Image Stabiliser
Optical (Intelligent IS with 5-axis Advanced Dynamic Mode)
Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction
Red-Eye Reduction
Flash +/- compensation
Effective Flash Range
0.5 m - 4 m (wide lens) , 2 m (tele lens)
Additional Features
Continuous Shooting Speed
4.6 frames per second, 5.9 frames per second
Self-Timer Delay
10 sec, 2sec
Additional Features
Built-in speaker, auto power save, digital image rotation, camera orientation detection, histogram display, AE lock, AF lock, cropping an image, resizing an image, i-Contrast (Intelligent Contrast Correction) system, in-camera red-eye fix, digital tele-converter, USB charging, Smart Flash Exposure, HS System, Zoom Framing Assist, Smart AUTO, Live View Control, GPS via mobile, Hybrid Auto
Display
3" LCD display
Display Format
922,000 pixels
Display Form Factor
Built-in
Display Features
Display brightness control
Microphone
Microphone Operation Mode
Stereo
Connector Type
USB 2.0 (mini-USB Type B) , HDMI output (19 pin micro HDMI Type D) , Composite video/audio output
JPEG 5184 x 3888 , JPEG 5184 x 3456 , JPEG 5184 x 2912 , JPEG 3648 x 2736 , JPEG 3648 x 2432 , JPEG 3648 x 2048 , JPEG 2048 x 1536 , JPEG 2048 x 1368 , JPEG 1920 x 1080 , JPEG 640 x 480 , JPEG 640 x 424 , JPEG 640 x 360 , JPEG 3888 x 3888 , JPEG 2736 x 2736 , JPEG 1536 x 1536 , JPEG 480 x 480
Video Capture
H.264 - 1920 x 1080 p - 60 fps , H.264 - 1920 x 1080 p - 30 fps , H.264 - 1280 x 720 p - 30 fps , H.264 - 640 x 480 p - 30 fps
