Zoom into the exquisite detail of distant wildlife. Capture stunning ultra-wide landscapes with this hugely versatile and gifted 65x Wi-Fi bridge camera, which combines fun with expert control.
Capture a huge range of beautiful shots. With an incredible 65x zoom and 21mm ultra-wide angle you can shoot everything from exceptionally detailed long range close ups of wildlife to impressive landscapes.
Effortlessly keep track
It's simple to keep track of distant subjects at high zoom. Simply press a button and Zoom Framing Assist quickly zooms the camera out of the scene - so you can relocate your subject - zooming back the moment it's released. Improved Auto Mode automatically zooms out when the subject starts to leave the frame and helps you keep your subject at a preset size.
Comfortable, steady shooting
Designed with your comfort in mind, you can enjoy steadier shots even at full zoom and shoot comfortably for longer periods thanks to a refined ergonomic grip. An Electronic Viewfinder offers SLR-like handling and lets you see clearly in very bright conditions. Ultra Sonic Motor (USM) ensures fast, silent focus and zooming.
Excellent quality in any light
Day or night your images will be just as you remember them. Canon's HS System - with DIGIC 6 and a 16.1 MP CMOS sensor - gives you stunning image quality and excels in low light. So it's easy to capture the real atmosphere of the moment without using flash or a tripod.
Sharp results every time
There's no need to worry about camera shake ruining your results thanks to an intelligent optical Image Stabiliser. This camera automatically adapts and ensures sharp, detailed photos even if you're shooting at full zoom or handheld in low light. Plus your movies will be spectacularly steady thanks to 5-axeis Enhanced Dynamic IS.
Always capture the moment
Life is fleeting. Don't miss a single precious moment and capture stunning split second action with super-responsive operation and sustained high-speed continuous shooting.
Stunning images with ease
Effortlessly shoot fantastic photos or movies with Smart Auto. Enjoy a fun HD (720p) movie summary of all the day's shots with Hybrid Auto.
Realistic movies at your fingertips
Making stunning movies is easy. With one touch of a button you can shoot smooth, realistic Full HD movies at 60p, with crisp and clear stereo sound thanks to silent controls and zoom. You can also attach an external microphone and manually control the levels of sound on camera for extra flexibility.
Connect with Wi-Fi
Enjoy the freedom of Wi-Fi. Upload images and movies to social networks - straight from the camera. Or transfer them to your smartphone or tablet, remotely control the camera from your smartphone and enjoy convenient PC and cloud backup with Image Sync.
Canon PowerShot SX60 HS - digital camera
Digital camera - compact
Memory Card Slot
SD card
Image Processor
DIGIC 6
Wireless Interface
Wi-Fi, NFC
Sensor Resolution
16.1 Megapixel
Max Video Resolution
1920 x 1080
Lens System
Zoom lens - 65x zoom - 3.8 - 247 mm - f/3.4-6.5
Focus Adjustment
Automatic, manual
Min Focus Distance
0 m
Digital Zoom
4x
Image Stabiliser
Optical (Intelligent IS with 5-axis Enhanced Dynamic Mode)
Built-in Optical Image Stabiliser
Face Detection
Print Standard
Direct print, DPOF support, Exif Print support, PictBridge support
Auto Focus
TTL contrast detection
AE/AF Control
Face-priority AF, Subject-tracking AF
Face Detection
Face Detection AF/AE/FE/WB, Face Detection Self-timer, Wink Self-timer, Smile Shutter
Digital Video Format
H.264, iFrame
Image Recording Format
JPEG, RAW, RAW + JPEG
1920 x 1080
Composite video/audio, HDMI, USB 2.0, IEEE 802.11b/g/n, NFC (Near Field Communication)
Connectivity Features
Remote control via mobile devices
Exposure & White Balance
Light Sensitivity
ISO 100, ISO 800, ISO 125, ISO 400, ISO 200, ISO 160, ISO 320, ISO 640, ISO 500, ISO 250, ISO 1600, ISO 3200, ISO 1000, ISO 1250, ISO 2000, ISO 2500, ISO auto (100-3200)
Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction
Red-Eye Reduction
Flash +/- compensation
Effective Flash Range
0.5 m - 5.5 m (wide lens) , 1.8 m - 3 m (tele lens)
Additional Features
Continuous Shooting Speed
3.8 frames per second, 6.4 frames per second, 4.6 frames per second
Self-Timer Delay
10 sec, 2sec
Flash Terminal
Hot shoe
Additional Features
Built-in speaker, auto power save, histogram display, AE lock, AF lock, resizing an image, in-camera red-eye fix, face detection, digital tele-converter, Smart Flash Exposure, HS System, Zoom Framing Assist, HDR image enhancement technology, Smart AUTO, GPS via mobile, Hybrid Auto
Viewfinder
Viewfinder Type
Built-in - electronic
Viewfinder Colour Support
Viewfinder Diagonal Size
0.17"
Viewfinder Resolution
922,000 pixels
Optical Viewfinder Field Coverage
100%
Display
3" LCD display
Display Format
922,000 pixels
Display Form Factor
Rotating
Display Features
Display brightness control
Microphone
Microphone Operation Mode
Stereo
Microphone Features
Wind noise reduction
Connector Type
USB 2.0 , Composite video/audio output , HDMI output (19 pin mini HDMI Type C) , Microphone (mini-phone stereo 3.5 mm)
JPEG 4608 x 3456 , JPEG 4608 x 3072 , JPEG 4608 x 2592 , JPEG 3264 x 2448 , JPEG 3264 x 2176 , JPEG 3264 x 1832 , JPEG 2048 x 1536 , JPEG 2048 x 1368 , JPEG 1920 x 1080 , JPEG 640 x 480 , JPEG 640 x 424 , JPEG 640 x 360 , JPEG 3456 x 3456 , JPEG 2448 x 2448 , JPEG 1536 x 1536 , JPEG 480 x 480 , JPEG 2768 x 3456 , JPEG 1952 x 2448 , JPEG 1232 x 1536 , JPEG 384 x 480
